Lesser Known Classics Discussion Forum
MasterCraft (BS) motor info needed please
Sean
04-26-2004 09:31:18
Hi there looking for any info regarding a Mastercraft 5HP rider, yellow small yet works great (B&S motor) but keeps choking itself out after @ 10-15 minutes running? Any help would be greatly appreciated many thanks, Sean
iqzero
05-14-2004 18:57:26
 Re: MasterCraft (BS) motor info needed please in reply to Sean, 04-26-2004 09:31:18
B & S engines wear out and start pumping oil past the valve stems and rings. This tends to foul the plug and will eventually cause the engine to stop running. If you remove the spark plug and clean it or replace ot the engine will run until it fouls again.
overhauling or replacing the engine is the only solution to this problem
