Lesser Known Classics Discussion Forum
long 460 brakes
ironhead
03-09-2004 13:42:09
something snapped on the right side. i looked in the manual and looks simple to get in side. what i was needing to know is, is there anything i need to watch out for or some hints that the book wont show.
marv
03-09-2004 20:54:05
 Re: long 460 brakes in reply to ironhead, 03-09-2004 13:42:09
Where are you going inside and why? How does it act? What are the symptoms?
ironhead
03-10-2004 02:41:33
 Re: Re: long 460 brakes in reply to marv, 03-09-2004 20:54:05
either the brake band broke or another piece. all the linkage outside of housing is fine. i was working her one day and when i used the right brake to help me turn i heard a snap and my foot went to the floor. if its not brake related, then i have no idea what it is.
Jason
03-10-2004 17:06:45
 Re: Re: Re: long 460 brakes in reply to ironhead, 03-10-2004 02:41:33
One thing to check before tearing it down. follow the rod back from the pedal where the clevis end hooks on look at the lever that is welded to the pin that goes inside. We hhave had many of them break the weld then the lever just spins on the pin. we just realign the broke weld and reweld it and works just fine. If you can't make sense of what I said I will know why but it is just hard to explain with out pictures.Very rare to see a band break.
ironhead
03-11-2004 02:50:29
 Re: Re: Re: Re: long 460 brakes in reply to Jason, 03-10-2004 17:06:45
thanks for the info. i wont be able to check it again until fri. or sat. ill post again and let you all know what i found
