Lesser Known Classics Discussion Forum
Water in the hydraulichs system
Don
02-19-2004 11:40:28
Hello All,
I have an older machine that I believe has water in the hydraulich system. The system holds 17 Gallons of fluid and I would hate to have to drain the entire system if I do not have to. Any suggestions on any additives that can be added which would dry up any water in the system? Sort of like what they make for gas tanks (dry gas).
Thanks for any replies
Don
gregg
02-26-2004 06:30:10
 Re: Water in the hydraulichs system in reply to Don , 02-19-2004 11:40:28
There is nothing to do but change it,just think of it as giving the ole girl a treat. If it is stored outside,the sun heats up the tank,and when it cools condensation occurs. Multiply this happening daily.
Seabee(Ga)
03-16-2004 03:18:47
 Re: Re: Water in the hydraulichs system in reply to gregg, 02-26-2004 06:30:10
I have a Kabota and the boot around the gear shift was catching water when it rained. draining was the only way I could fix.
Tony Knappen
02-25-2004 09:12:30
To my knowledge there is nothing to do but drain it. I got water in my Long's hydro fluid and actually called a shop about the same thing. Luckly my tractor only held about twelve gallons but still. If it helps think of it as maintance and there for it needs to be done. Sorry I was not more help.
Tony
