Lesser Known Classics Discussion Forum
Long 510
Eric
01-02-2004 18:13:17
Looking at a Long 510, unsure of year. It has tracks, blade on front, 3 point hitch (w/ hydraulic lines), and PTO. Engine sounds strong and appears to have low hours. Price is $8,000, but I don't know tractor values. Any input?
Thanks very much in advance for any insight.
Eric
Jason
01-06-2004 03:47:29
 Re: Long 510 in reply to Eric, 01-02-2004 18:13:17
I posted some pictures for those interested
Jason
01-05-2004 17:57:52
It sounds like you are talking about a 510s. There is only one problem with them the only part that are available are the engine parts the rest of it is NLA unless you can find use parts
Eric
01-07-2004 09:22:32
 Re: Re: Long 510 in reply to Jason, 01-05-2004 17:57:52
Thanks for the information Jason. I actually purchased the tractor at the end of December. I am interested in trying to boost the hydraulics a bit. Any advice on how to do that?
Thanks again for the input, Eric
Jason
01-07-2004 10:52:49
 Re: Re: Re: Long 510 in reply to Eric, 01-07-2004 09:22:32
You can try cleaning the Hydralic filter it is located under the seat right where the suction line goes into the hyd top.Plus the hyd system has it's own oil different from the transmission. It checked on hte back of the unit right beside where the top link goes, the trans check plug is under the right foot rest.If that don't help the relief vavle is under the front part of the seat.It is none adjustable so a new one will be required which I might be able to get yet for you
Eric
01-07-2004 19:00:16
 Re: Re: Re: Re: Long 510 in reply to Jason, 01-07-2004 10:52:49
Great info Jason. I'll check these points out and let you know if I'm needing an rv.
Thanks so much and I'll get back to you.
Eric
