Lesser Known Classics Discussion Forum
old tractor (co-op?)
sheila
12-18-2003 15:07:47
came into possession of this old tractor, wheels in front are real close together but wheels in back are big-it says "CO-OP" on front grill....not sure if it works/probably not...how do i know what it is? please help if possible..
thank you so much
P Heisey
12-21-2003 10:53:06
 Re: old tractor (co-op?) in reply to sheila, 12-18-2003 15:07:47
Hi Sheila,
There is a good possibility that it is a Co-op E3 tractor.
Does it have: rounded front nose? 4 cylinder overhead valve engine? cast steel engine tub frame?
The tractor serial number is stamped/punched into the top ledge of the tub frame between the engine oil dipstick and the radiator. The first numbers will be 47,48,49 or nothing, space, 30, space, a serial number from 101 to 50200.
Please let me know when I can assist you further with information and/or parts, new or used.
Phil Heisey 215-256-8651 eve. FAX 215-256-1203
Randy
12-21-2003 09:16:13
I went to Ebay and looked it up. Cockshutt came up. They have a discussion here on this site. Try them.
