Lesser Known Classics Discussion Forum
david brown 990 pto
ernie
10-22-2003 00:06:00
help!!
i have a early vintage db 990 that the pto will grind and not engage when the engine is running. I have to shut off the engine and engage the pto then start the tractor to get it to work.. also the hi spd pto will grind so i can only use the low spd.. any suggetions??
Andreas
02-22-2004 14:34:29
 Re: david brown 990 pto in reply to ernie, 10-22-2003 00:06:00
Hi,
To engage the PTO you need to press the clutch all it will go, if that does not work you propely have to adjust or replace the clutch.
Hope this helps,
Regards,
Andreas
_____ _____ _____
richard
10-25-2003 14:18:13
Check basic clutch adjustments,if o.k. then intermeadiate flywheel is rusted in-to the main flywheel causing the clutch not to release,remove clutch,free every thing off and reassemble. It is avery common problem if the tractor has been stood.
