Lesser Known Classics Discussion Forum
Leyland 384 Hydraulic pump.
Marty G.
09-17-2003 16:20:53
Hello everyone!
I've been out of the picture for awhile. I spend the last two months on an hospital bed. The cause, a head on car collision. I praise the mighty one for being alive and having my 2 legs. So while recovering, I decided to track down the owner of this tractor I was watching sitting for the last 2 years. My dad and uncle got the engine running today. It has a loader that is connected through the rear in the area of the PTO. The loader doesn't lift, it doesn't flinch at all. Does anyone know where that pump is located, possible access for inspection? Do you think I might have to prime it because of the time it's been sitting?
marlowe
09-17-2003 17:54:22
 Re: Leyland 384 Hydraulic pump. in reply to Marty G., 09-17-2003 16:20:53
on the 384 the pto lever has to be in the first notch for the pump to run and all the way back for both PTO and pump to run. this is live hyd. only when pump is in gear. this is a good feature so your pump dose't run when you don't need it
marty G.
09-18-2003 05:50:04
 Re: Re: Leyland 384 Hydraulic pump. in reply to marlowe, 09-17-2003 17:54:22
We tried all those combination and still there is no pressure at the loader. Is it the same pump that activates the 3 point hitch? The 3 point hitch fonctions properly.
marlowe
09-18-2003 17:17:15
 Re: Re: Re: Leyland 384 Hydraulic pump. in reply to marty G., 09-18-2003 05:50:04
yes it's the some pump. where is your loader plumbed in? is it on the rear remotes if so you have to lock your 3piont up there is a knob just behind the seat you turn 180 and lift your 3 point up by hand and it will lock up . then on your 3 point control levers {2} the one closes to the seat you have two pull UP and lock it that will charge your remotes
marlowe
09-18-2003 17:31:21
 Re: Re: Re: Re: Leyland 384 Hydraulic pump. in reply to marlowe, 09-18-2003 17:17:15
p.s if you want give me a call if that don't work but it should work spent a lot off time with the leylands and NEVER seen a bad pump 1-920 446-3296
Marty G.
09-19-2003 05:16:37
 Re: Re: Re: Re: Re: Leyland 384 Hydraulic pump. in reply to marlowe, 09-18-2003 17:31:21
Thanks alot Marlowe.
It was that little lever on the right side of the seat the we has to set properly. So now the loader works fine.
Thanks again for your time.
marlowe
09-19-2003 11:32:00
 Re: Re: Re: Re: Re: Re: Leyland 384 Hydraulic pump in reply to Marty G., 09-19-2003 05:16:37
just happy to be off help
