Lesser Known Classics Discussion Forum
Long PTO out
Gordon from s.
09-06-2003 10:32:12
Long 2460 PTO slips out when mowing even short grass. Removed top cover under seat. The forward gear is stripped. How do I replace? Is this a split the tractor job or can I remove it by taking the plate off from the back?
How do these wear out, tractor does not seem that old for this to happen?
Thanks.
geok
09-06-2003 21:07:56
 Re: Long PTO out in reply to Gordon from s. IL, 09-06-2003 10:32:12
I have not seen one stripped out either. But if someone operated the tractor like a fellow that borrowed one of my 610 one time. He had a 6 ft. cutter on the back and instead of letting the hand clutch down easily like you would raise a foot clutch up. He just dropped it at a high engine rpm. It didn't seem to hurt the tractor but both blades sheared each others mounting bolts off at the same time then fell on the ground.
