Mobility Dipper 2 info needed
Dave
02-07-2003 18:54:12
I have an oddball loader that is built like a forklift. It steers from the rear and has a good size bucket on front. It says Dipper2 by Mobility on the side. Any info on this 4cyl. gas engine??? Thanks in advance.
Dweston
07-20-2005 15:15:48
 Re: Mobility Dipper 2 info needed in reply to Dave, 02-07-2003 18:54:12
have a mobility dipper 4x4,i need to get parts for this thing
Brad
08-16-2003 11:19:04
Someone I know down the street has what you're talking about, it's sitting right near the road all covered up but you can see the dipper 2 on it, I know he's been aske to sell it, he's getting on in years, might be soon.
shrikant andge
02-21-2003 00:00:27
i want referances of design of electronically sensed automatic draft control in tractor of hp range 30hp to 75hp.
Phil Heisey-Harleysville, PA
02-08-2003 04:44:46
We used Mobility BIG Dippers in the fertilizer business between 1965 and 1990. They had 4 cylinder Ford Industial engines. These loaders were widely used at fertilizer blend plants. Factory refurbished Mobility loaders were still available in 1990.
Phil Heisey 215-256-8651 FAX 215-256-1203
Bill G.
02-08-2003 07:24:05
 Re: Re: Mobility Dipper 2 info needed in reply to Phil Heisey-Harleysville, PA, 02-08-2003 04:44:46
Mobility Big Dippers used Ford 172 cid Industrial engines and then the last ones (Dipper 2 (?))used White engines.
I'm interested in the earlier ones made before Mobility took over. They were originally designed and built for cleaning feedlots as I understand and had 4 wheel drive. Mobility built them for use in fertilizer blend plants and only in 2 wheel drive. Anyone with information on these early ones?
Dave
02-08-2003 08:34:16
 Re: Re: Re: Mobility Dipper 2 info needed in reply to Bill G., 02-08-2003 07:24:05
Thanks Bill and Phil for info on Mobility. Can I get parts for the Dipper2 two wheel drive? It runs but with a dead cyl it lacks power. Has spark, probably a burned valve. Phil says it utilized a White engine? I'll probably drive my parts dealer nuts when I ask for parts for this machine! A manual would be very helpful. Does anyone know where I can get one?
