Leyland 270 runs wild
marlowe
08-27-2002 17:53:39
neighbor has a 270 leyland that he use this morning stopped for lunch went out and started it up and it ran wild and had no throttle contorl would not shut down with fuel shut of he had to snubb it to stop it. any help would be appreciated THANK YOU
Don
09-06-2002 19:45:10
 Re: leyland 270 runs wild in reply to marlowe, 08-27-2002 17:53:39
Fist i would check to see if gas got in the diesel . If there is no gas present then the fuel rail is probaly stuck. To free the fuel rail take off the cover on the side of the pump . The cover has two bolts . Spay everthing down with penatrating oil and let soak . Next push in the shut off lever . take a big screw driver and gently but firmly work the rail until it frees up . You may have to also work the excess fuel button in and out to help get the rail loose . thats the button on the arm that turns the pump on and off. After the the rail is free drain the pump . the drain plug is on the bottom of the pump in the front it takes a seven sixteens wrench . Some times it helps to take off the outer nut that holds the pump on to get more room . You can fill the pump through the level hole on the side of the pump with engine oil . It takes a little over one oil can . change pump oil every time you change the engine . If this doest not work it is time to see the pump doctor . Hope this helps.
