Leyland 272
jstplan
05-30-2002 15:35:22
Does anyone have any experiences they would like to share about the Leyland 272 I just purchased.
Please be kind (Ha Ha).
David Reynolds
02-12-2003 10:38:14
 Re: leyland 272 in reply to jstplan, 05-30-2002 15:35:22
Leyland is a versatile medium powered tractor for 2 wheel drive. As a two wheel drive there is no better puller, have had MF185, IH 784, Ford 7610.
We use ours mainly for silage haulage, easily accessible pick up hitch for driver to see.
If engine is good and not letting in water from jackets then look after it it will serve you well - plenty of grunt (plus add a good exhaust sounds beautifull)
Hydraulic pump will let by oil with age which causes rear lift to go down and then compensate - annoying. Clutch needs alot of attention - don't abuse too much and if clutch is already bad then put in a new one now as it is the main down point - replacing the clutch - steering column, dash board comes out plus wiring - new clutch is lowered in and then slid along to fit in - tricky!!!
