What did I just buy?
Chris
01-30-2000 09:58:04
Hello all. I am a john deere collector that has just purchased the tractor he has always wanted.. An Oliver! However, there are no identifying marks on the tractor to tell me what model it is, and I am not familiar enough with Oliver (yet) to know. This tractor has a 6 cylinder diesel engine (the reason I wanted it) with the #4 and #5 rod bearing out.. There are some numbers cast into the block 190320E, 1K100D, and 8-5-53 which I assume is a casting date. "Oliver Row Crop" is cast into the front and rear sides of the axle housing. It has 13.6-38 tires, a three point hitch and remote hydraulic hookups. The casting number on the axle housing is 1K700C. The casting number on the frame is 1K500H. It also has an adjustable wide front end with. The wheels appear to be set about as wide as they can go both front and rear, read bieng 8'4" apart (outside to outside) and the fronts at about 8'. If anyone can help me identify this tractors so I can begin seraching out an engine or rebuild parts I would appreciate it.
Chris New found Oliver nut.
Larry Wolfe
02-13-2000 16:17:01
 Re: What did I just buy? in reply to Chris, 01-30-2000 09:58:04
With a 6 cylinder engine, it should be a 77 or 88. If it is a Super 77 or Super 88 it will have bolt holes drilled in the frame to mount cultivators on the side and front of the frame. If you can locate a serial # I can help identify the model (if it was made before 1960).
Mongo
01-30-2000 21:46:51
It would either be a 77, Super 77 or an 88, Super 88 by your description. I don't have my HPOCA mag handy to tell from the casting number. Don't despair, someone will get it figured out for you. It has been a long weekend at work for me and my thinking is kind of fuzzy right now. I just didn't want you to think we are ignoring you. My gut feeling is Super 77 or Super 88, does it have threaded holes on the sides of the frame where things can be bolted? I am guessing it does and has a flat plate just under the grill with a four bolt pattern there also. Either way, you have a good tractor worth fixing and both were top of their class in HP when made. Good luck to you.
Chris
01-31-2000 18:19:11
 Re: Re: What did I just buy? in reply to Mongo, 01-30-2000 21:46:51
I am not sure on the holes in the frame, but it does have a weight bolted up to the frony just onder the grill with a four bolt patter. The tractor has not come home yet (hopefully I will haul it home on Sunday..) but i will have pictures avaliable for e-mailing tuesday.
Chris
Dick L
01-30-2000 12:22:33
Chris, Go over in the photo gallery and pick out the Oliver that has the dash and grill shape close to yours and this will give you, or us if you share, a clue. Look for the serial plate, eather under the dash on the left side just below the break or under the foot plate on the right side close to the break cover. Someone mght be able to tell you something from the casting numbers but I can't.
