cubic in on Oliver motor
waco
12-18-2007 11:10:47
I have three complete waukesha engines with no tractors would like to know the cubic in on each of these.We have no books.
1. Butane stamp # on the right front is 56387 and the casting on the left back is 157829 A 221120 C 8263
2. Diesel stamp #55454 157328 A 221120 C 943
3. Diesel Stamp#14036 163371 A 221320 5187
B A Star
12-18-2007 22:24:36
 Re: cubic in on Oliver motor in reply to waco, 12-18-2007 11:10:47
    Number 157 809A was used in the late 1800 both HC & Dsl.  The cast date is August 26, 1963.   Don't know what number 157 328A was used in, the cast date is Sept 4, 1963.  Number 163 371A, the casting was poured on May 18, 1967, was used in 1750, 1755, 1850 and 1855.  Remember the numbers that you gave us are casting numbers, the repair part number could change with a change in machining.  As an example, same casting used HC & Dsl, however dsl engines have larger head bolts as compared to HC.  Yours is an original casting that Substitutes to 165 624A then to 165 625A.  something was changed in the casting, don't know what, look at head bolt size.
J Schwiebert
12-18-2007 17:33:12
I looked at the serial number and I checked my old records. We sold a tractor with an engine serial number within 50 of that second engine in the summer of 1964. On the last engine serial number wise you are missing a diget, most likely the last one. Now are these engines Oliver engines or are they engines Waukesha sold to someone else because that changes the rules of the game. I would also like ot have a picture of the second one if it is a Waukesha and not an Oliver engine. You need to remember you can take one block and make different cubic engines engines out of them.
waco
12-18-2007 17:59:24
 Re: cubic in on Oliver motor in reply to J Schwiebert, 12-18-2007 17:33:12
j i double chekd these numbers and theres 6 numbers and one letter so i know im not missing one . the numbers are 157329a on both engines thanks waco.
J Schwiebert
12-18-2007 18:43:35
 Re: cubic in on Oliver motor in reply to waco, 12-18-2007 17:59:24
No, no, I mean the stamped number for the last engine.
waco
12-18-2007 19:08:04
 Re: cubic in on Oliver motor in reply to J Schwiebert, 12-18-2007 18:43:35
dont know what you saying here are the numbers for them again the propane casting # is 157329a and 221120c and 8263 the stamp # is 56387. and the second is a diesl the casting # is 157329a and 221120c and 943 and the stamp # is 55454. the injection pump ser # is 349847 model# dbgfc631-icn ok the last is also a diesel and the casting # is 163371a and 221320 and 5187 the stamped # is 14036 the pump is missing on this one thanks for your help waco.
J Schwiebert
12-19-2007 01:28:50
 Re: cubic in on Oliver motor in reply to waco, 12-18-2007 19:08:04
Your stamped number on that last block should be a 6 digit. The earlies 1750 wwe sold in the fall of 66 had a 121 542 number. Your block is later than that as was pointed out to you so you should have an extra digit.
waco
12-19-2007 10:39:11
 Re: cubic in on Oliver motor in reply to J Schwiebert, 12-19-2007 01:28:50
You are right Lets start over;
1.Diesel stamp #55454 with a 3 port intake
2.Diesel stamp #140636 with a 6 port intake
3.Propane stamp #56387
waco
12-20-2007 13:22:29
 Re: cubic in on Oliver motor in reply to waco, 12-19-2007 10:39:11
J. could you check your email or go back a couple of topic I put in new numbers for (Waco). Hope this helps you help me. Waco & Me
waco
12-18-2007 16:33:47
you were right my numbers were wrong gettn old and blind the right one is 157329a diesel and the propane is also 157329a. thanks for your help! waco. also can you tell me the horsepower of these motors if not to much trouble
rp1555
12-18-2007 14:36:05
The first # 157829a is a fuel line elbow ,so that can't be. The second # I get nothing. The third # 163371a is a 310 for a 1750. Recheck your first two numbers.By the serial # I can guess the first two were built 1963/64 .The 1750 motor is 1967.
