oliver 1800 C head swap
cob_crusher
12-16-2007 05:17:42
i have a chance to buy a 1800c diesel for $ 1800.
i want to use it on mixer wagon and unloading forage wagon. pto is on left side. according to
it&t it is not a direct injection head. if i switch injectors and head during rebuild will this be aok. manual shows the " horse shoe " hydraulic oil cooler in front of radiator. does that mean that power steering unit is saginaw oem ?
J Schwiebert
12-16-2007 05:33:55
 Re: oliver 1800 C head swap in reply to cob_crusher, 12-16-2007 05:17:42
I don't think you have thought this out very well. You will need a different camshaft, injection pump recalibrated, manifolds fuel lines, etc. I am also not real sure all your coolant holes between the block and head line up. There used to be a dealer about 30 miles from where I worked who did a 1650. He told me never again. Myself, 1800 C diesel, set the horsepower at about 72 Horse and let it go. Easy on fuel and should pull your wagon with no problem. I don't understand your thinking on the steering. Saginaw (hydramotor) hydrostatic steering was standard. By now it may have been replaced with a Charlynn orbitrol unit. Were you thinking A Gemmer unit which was not used on C series to start with.
