Super 77 Industrial rear wheel removal problem
ollie wheeler
12-14-2007 16:55:06
I have a Super 77 Industrial that I cannot remove the right rear wheel. The tire goes flat every now and then. I would like to fix it but I cant get it off. I removed the wheel bolts but the cast center is rusted on. It is a split rim but the ring is to the inside so I cant just remove the rim. ANY IDEAS?I think it would be too much to heat all that cast up.
MIKE FRENCH
12-14-2007 20:22:05
 Re: Super 77 Industrial rear wheel removal problem in reply to ollie wheeler, 12-14-2007 16:55:06
Place a hydraulic jack that will work side ways between the drawbar and the wheel, use a good solid block of wood inbetween. Stay clear as sometimes they can go flying. Also have used a handyman jack but lots more dangerous
