Ken COWBOY Winiarski
12-14-2007 17:09:58
Re: Difference between 88 and Super 88 diesel's? in reply to J Schwiebert, 12-12-2007 17:23:16
The engine has a tag. Model 190GL,... Size 3-3/4 x 4,.... Gov Sp 1750,... The cast number on the left rear side of the block is 190320 and K100C,.... But the bore is only 3-1/2 inch. Rebuilt with wrong sleeves/pistons?,.... There is no port for a tach drive like on a 880 block,.... On the right side of the block upside down towards the rear top is 10-12-50,.... Battery box lid for 2 batterys, 6 volt type. Cover is somewhat big, but nothing to compare it to,.... The engine has a double oil filter assy mounted horizontally,... Clutch is 10 inch but will accept a 11 inch,... The intake doesn't have the name Oliver cast into it,... The head has 2 numbers, K180A and 191202,... The frame has 2 cultivator holes and 2 pads on each side plus the front mounting plate for weights,... Says 88 on top of grill,... Paint is worn badly but green and clover white wheels,... Has Disc brakes,.... Starter is from a 88 as determined by S/N of starter,... No key on dash, but there is a manual starter switch thru the dash on left, plus a manual starter rod to starter,... Light switch is a 5 position one,.... No S/N plate on the dash nor on the right side frame and can't see where any has ever been.
