Oliver super 55 starter
oliver 1600
12-11-2007 18:29:14
I there a generic general motors starter that can be used for parts in this application?
Homesteader
12-12-2007 13:24:58
 Re: Oliver super 55 starter in reply to oliver 1600, 12-11-2007 18:29:14
My starter went out in 2002 on my "54 Super 55. I took it to a local automotive electrical company for a rebuild. The cost wasn"t bad at all, and it"s still working perfectly. Might be worth thinking about.
J Schwiebert
12-12-2007 03:44:57
Is this a gas or diesel starter and then for gas 6 or 12 volt, for diesel does it engage with your foot or with a solenoid? Then what parts do you need?
oliver 1600
12-12-2007 07:53:26
 Re: Oliver super 55 starter in reply to J Schwiebert, 12-12-2007 03:44:57
12 volt gas, foot engage, brushes and armature.
J Schwiebert
12-12-2007 16:09:17
 Re: Oliver super 55 starter in reply to oliver 1600, 12-12-2007 07:53:26
Someone has changed it to 12 volt. All foot engaged gas starters are 6 volt. That was one reason the foot engage starter was dropped due to engagement problem associated with the linkage. 12 volt gas starter use a magnetic switch. Maybe you could post a tractor serial number and a starter model. Brushes should be failly easy and armatures can be rebuilt. J.
