Cockshutt 20 Hydraulic Problems
Lonnie W
12-11-2007 15:14:14
My father has a cockshutt 20 with a 3 point hitch.When you lower the 3 point hitch,it drop's like a stone.You can't lower it slowly.I have a manual and I've had the hydraulic's apart twice but can't solve the problem.Any advice on how to fix the hydraulic's on my father cockshutt 20.
Thank you,Lonnie
Lonnie W
12-12-2007 15:08:31
 Re: Cockshutt 20 Hydraulic Problems in reply to Lonnie W, 12-11-2007 15:14:14
I have had the hydraulic unit apart and there are no broken orings or springs.The 3point hitch will drop even the tractor is not running.I think that I will get a new kit and rebuild the hydraulic unit and see if that will solve my problem.Thanks for the help,Lonnie
P Heisey-Harleysville,PA
12-12-2007 01:42:12
Lonnie,
YES, I have the HYDRAULIC PARTS!
IRV, THANK YOU for your referral!
Phil Heisey 215-256-8651 FAX 215-256-1203
irv buttray
12-11-2007 16:41:01
Have you rebuilt the valve with new springs and orings? Off the top of my head I would guess you have a broken spring in the valve that just allows oil to push valve open with no resistance. It could be a blown O-Ring but they usually bleed down very quickly but not fall down as you put it. I usually have these kits and parts to rebuild them but am out right now. If you drop down a couple post you will see Phil Hiesey and he most likely has them in stock and ready to ship. One other question does the 3 point only do this when moving lever into down position or will it not stay in the up at all? Irv
