Return to �Still some hydraulic problems�
Fern(Mi)
12-10-2007 18:04:28
Sorry I haven�t added a thought to this problem before this. Actually I�m a slow thinker and then there�re times when I�m even slower than others. This was one of them.
A couple, four or five years ago I spent a half a day trying to figure out why a hydraulic cylinder was not working on a implement when I parked it, to failing on start up only hours later. Did all the oil filled pressure gauge checking both side both remotes (1850 Ollie). No problem with rock shaft nor steering.
Getting thoroughly pizzed the first time I replaced the quick coupling male hydraulic ends for the problem cylinder, the cylinder working then. When the same thing happened more recently I again replaced another male end on another cylinder. While this worked for me, it may be worth a try for you also. Fernan
1555nut
12-10-2007 18:48:09
 Re: Return to �Still some hydraulic problems� in reply to Fern(Mi), 12-10-2007 18:04:28
there are 2 little lines going to the pto take the lower line off put a 300lb pressure guage on it. tell me what the guage says
