Oliver Tach Gear
oliverhick
12-09-2007 13:22:51
Im looking for the gear that goes into the block to run the tach. Im trying to put a tach on my Oliver 88 Diesel but i dont have the gear. Can it be put in? Any help with it would be greatly appreciated.
Mike in MI
12-09-2007 17:15:11
 Re: Oliver Tach Gear in reply to oliverhick, 12-09-2007 13:22:51
Does your block have the opening to mount tack drive? Or are you just needing the gear itself? Mike
oliverhick
12-11-2007 11:00:18
 Re: Oliver Tach Gear in reply to Mike in MI, 12-09-2007 17:15:11
It has the hole on the right side of the block( from the seat) and i have the cable but the motor that i got that from has the gear in it, we dropped it into the motor by accident. so all i need to know is will a gear from any block fit and does it matter if it goes in from the side or down from the top.
J Schwiebert
12-09-2007 18:06:58
I would use a later tach drive that comes out where the distributor would go.
