cockshutt 30 hyd control
M in Sask
12-07-2007 06:06:02
third party image
Hello The 30 is just about done as I painted the wheels yesterday . Can anyone tell me or show me a picture of the control rod for the hydralic, and how it was mounted? this tractor came to me in a basket, I have not seen another one with hyd. and no 3pt to look at. I sent a pic of it before build up . (if I figured out adding a pic ) Thanks Merv
M in Sask
12-09-2007 07:49:31
 Re: cockshutt 30 hyd control in reply to M in Sask, 12-07-2007 06:06:02
Thanks for the pic Matt. I got it set up Merv
Matt_In
12-08-2007 09:16:47
 Re: cockshutt 30 hyd control in reply to Opps, 12-07-2007 06:06:02
third party image
Maybe this will help. I can get closer pics, but not until Monday or so. This is a 1947 E3
M in Sask
12-07-2007 07:02:46
third party image
sorry here is the pic
P Heisey-Harleysville,PA
12-08-2007 03:52:11
 Re: cockshutt 30 hyd control in reply to M in Sask, 12-07-2007 07:02:46
Merv,
If you have the early style hydraulics, the straight control rod attaches under the rectangular alumimn valve assy...next to the hydraulic pump and is connected to the hand control assy. that is mounted to the side of the dash/steering assy.....above the clutch pedal.
If you need more, I can fax or mail you info.
Phil Heisey 215-256-8651 FAX 215-256-1203
M in Sask
12-08-2007 07:05:31
 Re: cockshutt 30 hyd control in reply to P Heisey-Harleysville,PA, 12-08-2007 03:52:11
Thanks for the reply Phil did the rod just go through a peice of flat iron bent to 90 degrees that bolted to the dash? Also what is involved in repairing a leak at the shaft the control rod is atached to? Thanks again Merv
