Engine compression
martin fleming
09-16-1998 20:29:12
Hello,
I'm wondering what the compression should be on a OC-3 (4 cyl hercules gas engine)
Anyone know?
thanks,
martin fleming
mm
09-18-1998 17:21:53
 Re: engine compression in reply to martin fleming, 09-16-1998 20:29:12
: Hello,
: I'm wondering what the compression should be on a OC-3 (4 cyl hercules gas engine)
: Anyone know?
: thanks,
: martin fleming
Hi, Ideally the compression should be the compression ratio times atmospheric pressure, 14.7 psi. So if you know what your compression ration is you should know the answer is.
martin fleming
09-18-1998 22:03:02
 Re: Re: engine compression in reply to mm, 09-18-1998 17:21:53
: : : Hello,
: : I'm wondering what the compression should be on a OC-3 (4 cyl hercules gas engine)
: : Anyone know?
: : thanks,
: : martin fleming
: Hi,
: Ideally the compression should be the compression ratio times atmospheric pressure, 14.7 psi. So if you know what your compression ration is you should know the answer is.
Okay, I'm getting closer, thanks for the info. Now, does anyone w\know whatthe compression ratio is for the OC-3 engine?
~martin
