Hydra-power oil?
Nusbaum Farms S
12-03-2007 09:29:30
What type of oil do I use in a 2-speed hydra-power? My service manual says to see the operators manual, but I don't have one. I'm assuming I use ATF like in the newer 3-speed Over/Under Hydraul, but would like assurance.
Thanks.
Scott
rrlund
12-04-2007 05:47:57
 Re: Hydra-power oil? in reply to Nusbaum Farms SCWI, 12-03-2007 09:29:30
It says right on the dip stick typeA auto trans fluid.Like Brad says,you can use hydra tran. I changed my 1850 over to it because it leaks a little and I have it on hand. But,my 1550 and 1600 are still on trans fluid. To be honest,I prefer the trans fluid to the hytran. The 1850 seemed to work better before I changed it over.
Nusbaum Farms SCWI
12-04-2007 16:51:52
 Re: Hydra-power oil? in reply to rrlund, 12-04-2007 05:47:57
You're right, it does say on the dipstick. I just pulled the drain plug expecting to see red ATF, and out comes what appeared to be hyd oil. It threw me for a loop. So I went to the service manual, then here. Never thought to look at the dipstick. I think I'll stick with the hyd oil since that is what drained out and everything seemed to work fine. Thanks for the help everyone.
Scott
dwm7
12-03-2007 15:53:07
Yes the same oil is what I always use. ATF
bradk
12-03-2007 09:53:13
Some guys like ATF,some like universal hydraulic fluid.Both work fine.
I prefer universal hyd fl.in hydra-powers and over/unders. ~brad
