Hooking up the original 1650 tach to a Cummins
e
12-02-2007 06:57:01
For those folks who have done the Cummins conversion into an oliver, how have you hooked up the tachometer? Is a tach drive avalible from Cummins?
Thanks!
Shep Va
12-04-2007 04:52:28
 Re: Hooking up the original 1650 tach to a Cummins in reply to e, 12-02-2007 06:57:01
I have always used electric tachs, either Murphy or Isspro and hooked them to a sensor in the bellhousing or put a diode in the alternator to drive the tach.
They are not origional but the electric tach do work nice.
Just another option.
BM
12-03-2007 08:18:02
I have a angle drive and cable to work with that. just need to know what injection pump you have because different pumps have different size nuts which make the adaptors different.
Wrenchbender
12-03-2007 06:39:21
The B series Cummins tach drive is off the front cover where the injection pump drives. I don't know if the drive ratio would be the same though. WB.
