60's front wheel seal
linemanfarmer
11-29-2007 18:05:30
Hi guys, Im restoring this 1945 60 row crop for a fella, and replacing the bearings in the front wheels, well I can't believe im letting this wip me, but how do those seals come off the hub? I found a notch and now wondering if those are threaded but I can't belive that. Thanks for the Help!!
Derek
Ken L.
11-29-2007 19:03:48
 Re: 60's front wheel seal in reply to linemanfarmer, 11-29-2007 18:05:30
If it has the origingal seal, they should be felt. Under the felts, there is a (cup) that they sit in. If you clean it up good, you should be able to see a lip that comes up over the edge of the hub. Take a thin chisel and tap it between the lip and the hub in a couple places and it should start to lift out of the hub. Once it starts to move, you should be able to pry it out of the hub.
