Oliver SUPER55 fluids
Wallace Robinso
01-27-2000 19:36:24
Can anyone tell me what fluids go in the 2
filler caps in front of the drivers seat, and which is which ?
Mongo
01-28-2000 13:59:54
 Re: Oliver SUPER55 fluids in reply to Wallace Robinson, 01-27-2000 19:36:24
The big cap at the base of the dash is to the transaxle. There are 3 plugs in the belly to drain the transaxle, when empty- replace plugs and remove the little plug to the right of the PTO shaft and fill with gear oil (I use 80W 90) until it comes out the plug hole. This takes right at 5 gallons. The plug under the seat goes to the hydraulics. It should have a dip stick on it. The filter is in the cylinder just beside the cap to the tranny case. Some have a remote valve others don't so saying how to empty the hydraulics varies. The best rule of thumb for the hydraulics is to use the lightest non-detergent oil you can and still have the lift operate properly. I believe it came with 10W oil in it. I use 20W-20 non detergent with good success. Good luck.
