60 Bearings
Anderson
11-29-2007 11:10:32
Are the rod and main bearings really the same on the 60 and 66? I was told they are, just that the oil holes are located in different spots.
J Schwiebert
11-29-2007 12:52:38
 Re: 60 Bearings in reply to Anderson, 11-29-2007 11:10:32
Rod bearings on an Oliver 60 and 66 & 77 gas engines are the same. 66 & 77 diesel are same size but different material. Main bearings will need holes drilled in them.A few years ago F-M did list a set of mains for an Oliver 60 yet. More questions? J.
Anderson
11-29-2007 14:38:57
 Re: 60 Bearings in reply to J Schwiebert, 11-29-2007 12:52:38
What about the pistons and sleeves?
J Schwiebert
11-29-2007 16:33:33
 Re: 60 Bearings in reply to Anderson, 11-29-2007 14:38:57
Bore the old sleeves out and put yourself a set of aluminum pistons in there by far the cheapest way to go. No they do not fit. Stroke is longer pin size is different, how many differences you want me to list?
