Just curious...
formenwhogrow
11-29-2007 06:59:48
I was pondering this last night and I was just curious, is there a way to install an over/under (ie like one out of a C series 1650 or 1550) in an 880? Or perhaps even a 3 speed? Has anyone ever done this? If it is possible, what would be required(frame mods, mounts, lube,etc)to do it?
Just wondering.
joho
11-30-2007 04:08:48
 Re: Just curious... in reply to formenwhogrow, 11-29-2007 06:59:48
It can be done, but you have to use a 1550 tub.
MIKE FRENCH
11-29-2007 09:34:59
a 3 speed can be installed in an 880 if you want to lengthen the frame at the rear, tin work will have to be moved forward also. I started to build a new front frame to use for a pulling tractor but never got it done. Lots of work for what you want to do, my 2 cents
