choke 1550 gas????
SJ
11-28-2007 13:48:05
The clamp that holds my choke cable broke away from the choke lever on the carb.How do you reattatch this part? The bungi cord hooked to my choke lever is gettin to be a real pain,lol.
Thanks
Stan
1755
11-29-2007 19:02:56
 Re: choke 1550 gas???? in reply to SJ, 11-28-2007 13:48:05
I have not ever looked at the carborator choke setup on a 1550 but is it just a litel peice of metal that has a litel bolt holding it on or is it the one that holds the inner part of the cabel to the choke lever the one that clamps the out side of the cabel can you use a hose clamp and sinch it down some where like the fuel line if it is a steel line you might put a piece of inner tube or something in there to keep it from whareing threw the line or make anothere one from a piece of scrap metal if it is the clamp for the inside can you bend a coupel of 90 degre turns in there and drill a smaller hole in the lever some where and rig it up like they do on the throtel cabel on a push lawn mower or what ever Brigs and Straton use to use this set up but ours is 10 years old Hope this helps Thomas
rrlund
11-29-2007 06:47:39
Mine's been gone all the years that I've had it. The cable's zip tied to the gas line with two zip ties. Works.
