Electronic Ignition for 77
IAOliverTeen
11-26-2007 17:36:23
Has anyone put one on a 77? Will it make that big of a difference for pulling? What model or part number do I need from what company? Thanks for any help. -Dan
IAOliverTeen
11-28-2007 09:17:30
 Re: Electronic Ignition for 77 in reply to IAOliverTeen, 11-26-2007 17:36:23
Thanks for all of the advice. I'll probably look into changing it over this winter. Sounds like a quick easy winter project.
John T
11-28-2007 06:37:50
Teen, As far as pulling, if you compared an elec ignition equipped tractor with an exact idential standard and well tuned good ignition, the elec may offer slight more HP but its not gonna be any super great improvement. If you go with an elec ignition switch, to get the most bang for the buck and all the benefits it has to offer, I recommend you couple it up with a high energy high voltage coil (matched to the elec. switches capacity) and run a wider plug gap for a wider hotter higher energy spark. Use good quality plug wires of course.
It can help starting performance and perhaps reduce premature plug fouling plus gain you some degree of improved performance, and if I were pulling and it was allowed Id definitely use one to gain whatever (even if small) performance advanatge I could.
John T
Bob
11-27-2007 11:24:04
For a basic EI, you can go to the Pertonix website, access the AG catalog, and look up the part number.
Then, part number "at hand", shop around for price. This very site has the Pertronix units at fair prices for many applications.
rrlund
11-27-2007 06:00:50
I got one for my 1550 from Gennessee Products a year ago just because I couldn't keep points in it.I think it was around $95. It starts a lot quicker,but no difference in power. A lot of clubs won't allow electronic ignition for pulling for some reason.
Johnnie T
11-26-2007 18:37:48
I put a Petronix brand on a 1850 I don't think I get any more power just don't have to worry about points. Give Tom at O'Brien Impl. in Iowa a call 1 800 320 6224 he can help U out Johnnie
