white 2-135 ?
cob_crusher
11-23-2007 12:34:13
does the herc 478 have a mech lift pump from
fuel tank to filters ? oem do they have water
sep & fuel filter ? where is fuel tank & how big is it ? my it&t manual shows nothing.
MCL
11-25-2007 16:33:25
 Re: white 2-135 ? in reply to cob_crusher, 11-23-2007 12:34:13
Someone commented on the fuel tank(s). They all had a tank under the hood and one down on the right side of the frame under the cab. The early ones filled indvidually. The later ones filled both through the top tank. The plumbing and wiring for the gauges is complicated. There are vented and non-vented caps that have to be on the right tanks to make them feed right also. No sense getting into that until you know what type you have.
cob_crusher
11-25-2007 03:58:05
how do parking gear & gear shift lever interface ? is there a lock out mechanism ? i hope it is not like ford where you could be in park & place in gear. i have seasonal help
& have to prevent problems
mkuhns
11-25-2007 12:51:57
 Re: white 2-135 ? in reply to cob_crusher, 11-25-2007 03:58:05
You can't engage the park unless the transmission is out of gear. However you can put the trans into park with tractor moving, possiblly ruining the park pawl that engages into the pinion gear.
cob_crusher
11-24-2007 03:38:10
it&t electrical diagram shows a fuel solenoid. is that a transfer pump. also does motor have a block heater ?
mkuhns
11-24-2007 16:30:32
 Re: white 2-135 ? in reply to cob_crusher, 11-24-2007 03:38:10
The fuel solenoid is part of the injection pump which turns the fuel on and off inside of pump. If it has a factory block heater, it is on the right side in one of the block freeze plugs.
mkuhns
11-23-2007 17:20:10
Transfer pump is part of the fuel injection pump. It has two glass fuel filters on it in a row on the left side of the engine. I think the rear one is supposed to be a fuel water seperator and the front one is the fuel filter. (two different filters that can but shouldn't be interchanged) I'm not sure if yours has two fuel tanks or not. Ours has one in front of the cab under the hood that is about 35 gal and on the right below the cab along the framerail that is about 35 gal. The two tank are connected in series. Filling the top tank fills both tanks. The fuel supply to the engine comes from the bottom tank, while return fuel goes to the top tank. We had problems with dirt clogging the elbow/fitting coming out of the lower tank supply fuel to the engine.
newter haven
11-23-2007 17:33:08
 Re: white 2-135 ? in reply to mkuhns, 11-23-2007 17:20:10
Had that same problem with our 110, clogged at the elbow, not dirt, but something that resembled pond scum. No kidding, pulled it out, tractor started and ran fine. Chalked it off to one of those days, you know?
