7300 clutch fixed
rrlund
11-20-2007 09:55:47
I got the clutch freed up on that 7300 combine today without doing surgery. I got up under it to start unhooking things and found a big tin plug on the back side of it. Just as a last ditch effort,I popped it out and sprayed a little PB Blaster on the shaft and up over the disc. Let it sit a few minutes then started it in gear. Held the pedal down and hit the brakes and she started letting loose a little. Kept working it and she's loostened up OK now. Actually stops and shifts alright. Saved a days work there.
