Cockshutt 30 block cracked
Nebraska K
11-19-2007 19:27:21
I am rebuilding this tractor for a neighbor. When I pulled the head off I found three hair-line cracks. Two of the cracks go from the water hole in the middle of the block to #3 sleeve and one to #2 sleeve. The third crack goes between #1 and #2 sleeve. Do I need to start looking for a different block? Will these let water into the oil, or will the o rings on the sleeves stop the water. I have some good pictures of the cracks if someone can tell me how to post them on here.
Thanks Nebraska K
The
leroy in ne
11-20-2007 10:34:06
 Re: Cockshutt 30 block cracked in reply to Nebraska K, 11-19-2007 19:27:21
have 30 parts tractor located 35 miles southeast of lincoln email me leroy
J Schwiebert
11-20-2007 03:43:21
I worry about one other thing which is also repairable with not too much work. More later in the week. A lot blocks have the block cracked like in the lower photo. J.
RAB
11-19-2007 23:20:59
Was it leaking previously? Are you changing the sleeves? Did they cause any trouble with the gasket previously? I would think there are a lot of similar cracks out there. They can be repaired but I would not worry if nothing is being disturbed and they have not caused any problems. Could have been there years.
Regards, RAB
Nebraska K
11-20-2007 06:41:32
 Re: Cockshutt 30 block cracked in reply to RAB, 11-19-2007 23:20:59
Thanks guys that makes me feel better. I have no idea if it was giving any trouble before. There was another man working on this tractor before me but he became ill and passed away. The tractor has set for many years at his place and there is no way of knowing what he found when he first took it apart.
Thanks for the info guys
Nebraska K
Nebraska K
11-19-2007 20:29:03
third party image
I figured out how to post picture. Here are the two cracks in the middle.
Nebraska K
11-19-2007 20:33:30
 Re: Picture of block cracked in reply to Nebraska K, 11-19-2007 20:29:03
third party image
Here is the third crack.
Dave Sherburne NY
11-20-2007 16:03:16
 Re: Picture of block cracked in reply to Nebraska K, 11-19-2007 20:33:30
Mine was cracked like this lower photo, not a problem.
