oliver 77 charging problem
roy bichler
11-19-2007 18:39:30
I just finished restoring a 77 standard. I had to switch it back to a 6 volt system. I got a new generator,regulator and coil. I polarized the regulator. I put a voltage tester on the battery when it is running and it is not showing that it is charging. It shows that the battery is a little weak, before I start it. So I am thinking it should show charging. How can I tell what is not working, that it is not charging?
J Schwiebert
11-21-2007 07:44:12
 Re: oliver 77 charging problem in reply to roy bichler, 11-19-2007 18:39:30
There are 2 different charging circuits. The A circuit which you would have if you went back to A Delco system. In this system the field circuit is grounded in the regulator. The other circuit is know as the B circuit which was used on Ford tractors as well as some imports. In a B circuit the field is grounded in the generator. How did you polarize your system?
Bob
11-19-2007 18:59:52
The GENERATOR is the component that needs polarizing, NOT the voltage regulator, although "jumping" the proper terminals at the regulator DOES polarize the GENERATOR.
What brand of charging system does this tractor use?
The battery voltage, while charging, should measure about 7.4 Volts, IF the charging system is functioning.
roy bichler
11-20-2007 18:34:12
 Re: oliver 77 charging problem in reply to Bob, 11-19-2007 18:59:52
I am not sure what you mean by what brand of charging system.
Is there away I can polarize the generator itself.
Thanks
