Oliver 60 Shift Pattern Plate
RCP
11-19-2007 14:12:43
Trying to find a shift pattern plate for an Oliver 60 with a three speed transmission, any ideas? BTW this tractor has 1,2 and R in the top of the pattern and 3 in the lower pattern.
ollie770
11-20-2007 20:31:46
 Re: Oliver 60 Shift Pattern Plate in reply to RCP, 11-19-2007 14:12:43
I have gotten shift plate decals from Dumonts in Iowa - website is www.oliverdecals.com and they are the best in the business.
Ron Grother
11-20-2007 02:16:33
I would like the serial # on that 3 speed
Luther
11-19-2007 18:09:49
Ron said they never made a 3 speed . Thats funny I have one
Ken L.
11-19-2007 17:23:50
The 60s never had a shift pattern plate, there was just a decal. 4th gear should be in the same position in the lower neutral as 2nd is in the upper neutral.
J Schwiebert
11-19-2007 16:11:27
Is the gear shift handle straigh or curved. Curved handles are 5 speed, straight handles are 4 speed.
RCP
11-19-2007 16:32:19
 Re: Oliver 60 Shift Pattern Plate in reply to J Schwiebert, 11-19-2007 16:11:27
The handle is straight, but I can only find 3 forward gears, where is the 4th gear?
Where can I get a shift plate?
Dsl
12-02-2007 18:54:17
 Re: Oliver 60 Shift Pattern Plate in reply to RCP, 11-19-2007 16:32:19
I learned to drive on a 1941 Cockshutt 60 Row Crop that Dad bought new. It was a straight stick (4 speed). It's been a long time since I've seen that sweet little tractor, but, as I remember:
Upper Neutral (shove stick up through center of neutral), then:
1st: lower center
2nd: upper right
Reverse: over left and up alongside the steering column.
Shift to HI neutral (pull stick DOWN through center of neutral), then:
3rd: lower center
4th: upper right
Hope this helps, and thanks for helping me see her in my mind's eye and feel her in my hands again.... :-)
Ron Grother
11-19-2007 15:58:31
they never made a 3 speed it must a 4 or 5
