power booster parts
Ed Hodge
11-18-2007 07:46:26
does any one have the sprag clutch and internals parts for oliver 880 power booster??
Vito
11-18-2007 13:20:43
 Re: power booster parts in reply to Ed Hodge, 11-18-2007 07:46:26
Ed,
Try Spencer in Maine.I know he had one for sale awhile ago.Think it was of a 770. Hope this helps.
Vito
Ed Hodge
11-18-2007 13:26:57
 Re: power booster parts in reply to Vito, 11-18-2007 13:20:43
thanks vito i for got spenser had one
J Schwiebert
11-18-2007 10:27:33
Why don't you pull the engine and see what all you need before you order any parts. Pull the hydraulic unit and clutch as well just for good shop practices.
Ed Hodge
11-18-2007 12:47:03
 Re: power booster parts in reply to J Schwiebert, 11-18-2007 10:27:33
i was told that my 880 has ATF in the rear i drained it last night and put 80-90 gear oil in. it seems to work better now but still slipping
ADB-IA
11-19-2007 06:27:52
 Re: power booster parts in reply to Ed Hodge, 11-18-2007 12:47:03
For what it"s worth, the book recommends lighter oil in there to properly lube the power booster. It"s not a pressure lube system - oil just runs in through a port between the unit and the transmission. Also if it is slipping in the high side it might just need shims taken out of the clutch pack - totally unrelated to the sprag clutch. That can be done from the outside without removing the unit. ADB-IA
Ed Hodge
11-19-2007 15:19:28
 Re: power booster parts in reply to ADB-IA, 11-19-2007 06:27:52
its sliping on the low side there is 80-90 oil in the rear now
Ed Hodge
11-18-2007 11:06:15
i want all the parts ahead of time clutch power booster parts dont wont the tractor sitting around to long apart dont have my owne shop
770
11-18-2007 11:19:39
 Re: power booster parts in reply to Ed Hodge, 11-18-2007 11:06:15
Maibachs in ohio sells them. I even think they can hook you up with a HD sprag?
smerr
11-19-2007 20:16:14
 Re: power booster parts in reply to 770, 11-18-2007 11:19:39
I"ve never heard of a HD sprag? What is the part number?
770
11-20-2007 06:44:58
 Re: power booster parts in reply to smerr, 11-19-2007 20:16:14
A few years back, I talked to Brad over there. I was going to re-build one for my puller, and he told me of one from a different application that fit up no problem and would hold more horse/torque easily. well, I came to my senses and never put it in. Give him a call, I think the # is 1-330-939 4192?
