Power Steering Line Leak
SW3
11-17-2007 06:51:29
One of my power steering lines has always leaked where the fitting threads into the power steering housing. It is a flare end on the line and appears to be an inverted flared in the housing. In an attempt to fix it I bought a new line, bent it to match the old one, and replaced it. However, it still leaks. Any suggestions on a fix? Would it be possible to add an 0-ring in there to seal it up better? Thanks.
J Schwiebert
11-17-2007 17:10:08
 Re: Power Steering Line Leak in reply to SW3, 11-17-2007 06:51:29
They are inverted flare. At one time the insert with the flare inside the housing was replaceable. I thought a little on your problem today. Me, I would clean the fitting with brake clean and then put a very thin coat of blueing on the flare, tighten it up and see where I didn't have contact. I don't get your O-ring idea. A flare seals on line contact.
