Oliver 1855 PTO
DLJ
11-17-2007 00:45:35
Can The 1000 RPM PTO Be Changed To 540 PTO
Don-Wi
11-17-2007 07:48:40
 Re: Oliver 1855 PTO in reply to DLJ, 11-17-2007 00:45:35
Yes. on the 1855, the shaft is held in by 4 bolts. Remove them and pull the 1000 RPM stub shaft out, and then on the lower right hand side of the back cover, there is a shifter. There is a bolt that holds it in place from the bottom, and it had 3/8-16 threads in the end of the shifter to stick a bolt in it. Shift it to 540 (pull it out) and stick the 540 stub shaft in. I find it often helps to stick the stub in partially to turn the gears a little bit so they"ll line up.
There is a button in there as a safety feature, so the 540 shaft can"t be used when it"s set to run 1000 RPM.
Donovan from Wisconsin
DLJ
11-17-2007 08:03:31
 Re: Oliver 1855 PTO in reply to Don-Wi, 11-17-2007 07:48:40
Thank You For The Information So Quick I Will Looking At This Tractor Today.
Dennis
leroux
11-17-2007 02:13:34
Yes. Snap ring holds in shaft. Remove it and pull shaft. Lower right side of rear-ed housing has and push pull lever. Loosen jam nut, and pull pin to out position. You should feel a slight snap which means it is right position.
DLJ
11-17-2007 08:13:38
 Re: Oliver 1855 PTO in reply to leroux, 11-17-2007 02:13:34
Thank You For The Answers So Quickly. This Information Is what I need To decide Whether This Machine Will Work For Me.
Thank You, Dennis
