Oliver 88 piston
kevin
01-25-2000 18:31:51
Require information for model 88 piston bore. Have unit with 3 7/8 bore that apparently is not standard. Is this a super 88 bore? Unit has a MW 5 ring piston with 1 7/16 wrist pin bore. 1/2 of piston has a dome. Any idea of where to find a piston like this?
WFE
01-26-2000 09:29:48
 Re: oliver 88 piston in reply to kevin, 01-25-2000 18:31:51
Pretty sure Super 88 bore is 3 3/4 with a stroke of 4". But since the tractor is this old, a 3 7/8" bore was probably available to overbore the stock engine from companies like M&W. M&W also sold a lot of the domed pistons like you have so this sounds plausible. I have recently been informed that you can get replacement M&W parts, but I do not remember the name of the company. Perhaps contacting a number of engine rebuild kit suppliers would lead in the right direction. Best of luck.
