Oliver 70 Rebuild Help
J. R. Tierney
11-13-2007 18:21:34
I am rebuilding the Continental engine in an Oliver 70. The original main bearings had a single flange, with a thrust washer on the opposite side. The thrust washer has 3 brass dows to hold it in position. The replacement front bearing is a straight shell type, with no flange, and 2 thrust washers. There are no dows in the block or cap. Can this inner thrust washer simply float, or will I need to drill the cap or block for dows to prevent it spinning, and wearing on the block surface? Thanks in advance for your advice.
eeeeeeeeeeeeeee
11-14-2007 14:02:44
 Re: Oliver 70 Rebuild Help in reply to J. R. Tierney, 11-13-2007 18:21:34
are you ordering new pistons and sleeves, if so can you tell me where to get them. I am trying to rebuild a 70 engine and i am in a big hole
J. R. Tierney
11-14-2007 18:38:53
 Re: Oliver 70 Rebuild Help in reply to eeeeeeeeeeeeeee, 11-14-2007 14:02:44
I have a 70 engine with nearly new 3.25 pistons and sleeves. I was planning to sell the engine when my pulling engine is completed. We could probably work a trade cheaper than the cost of a good rebuild.
Call or email if you are interested.
Thanks,
James
608 334 2219
Larry NE IL
11-14-2007 12:51:26
J.R.
I can't help you and apparently nobody else can. Mabey try Larry Harsins' site. He has an "ask the Mechanic" page there.
Good Luck, Larry NE IL
J. R. Tierney
11-14-2007 18:40:11
 Re: Oliver 70 Rebuild Help in reply to Larry NE IL, 11-14-2007 12:51:26
Thanks for the suggestion - I will give it a try.
