Super 55D battery(s)
Chief 83
11-11-2007 17:49:55
I'm moving closer by the day on this thing. Just changed out a leaky seal and replaced the pto clutch discs. Not as tuff as I thought it would be but still took several hours.
I am about ready to run some wire and put in the battery. I think it originally has twin 6v but I'm considering just one larger 12v. What do you think?
Mike (WA)
11-12-2007 21:27:49
 Re: Super 55D battery(s) in reply to Chief 83, 11-11-2007 17:49:55
I"ve tried it both ways on my 550 diesel. Didn"t see much difference- so I went back to one 12, which is certainly less $$ than 2 sixes.
Chief 83
11-13-2007 17:34:12
 Re: Super 55D battery(s) in reply to Mike (WA), 11-12-2007 21:27:49
I'm leaning towards a single 12. Less connections to deal with. My guess is that some of the reason for the dual 6v has been eliminated with the newer 12v stuff. Thanks everyone.
rrlund
11-12-2007 16:34:21
I think you'll get more cranking amps from the 2 sixes. Use good heavy battery cables. That starter's gonna draw a lot of amps.
LenND
11-11-2007 18:31:46
If this is any help. All I have ever used in my 900 Case is a 12 volt Truck-Tractor battery and that has been for quite a few years.
