1966 oliver 1850 diesel
allen
11-11-2007 09:56:37
Is there enough room to remove the injectors without removing the hood/fuel tank? Also the power steering does not work! I have never seen a set up like this! Tractor belongs to my neighbor and am trying to help him out.
Fern(Mi)
11-11-2007 18:32:19
 Re: 1966 oliver 1850 diesel in reply to allen, 11-11-2007 09:56:37
We've had to clean the priority valve on the left side of rack arm shaft housing, finding valves stuck open with small bits of foreign matter. That cleaned and a new filter things were fixed.
Why are you removing injectors? Check them out opening fuel line to each one running. If it misses, that one is working. Enough missing take them out for rebuild?
Side panel is not all that hard to remove. Injectors can be stubborn.
Fernan
Kelly MT
11-11-2007 17:16:30
Is it a four wheel drive? The hydraulics and steering come from the same pump via a flow devider. Do the hydraulics, three point & remotes, work ok. pk
rrlund
11-11-2007 10:36:41
What do you mean by "doesn't work"? You can't turn the steering wheel or it turns and the front wheels don't?
