cockshutt 1555
jakemb
11-10-2007 13:04:27
I got to use my new tractor a little today and was pushing up piles of wood for burning I noticed twice that once the tractor is in gear it will not move.The second time it happened I looked to see if the couple into the trans was turning and it was.I could put the tractor in andout of 4th gear without the clutch with only a very slight grind.I was ready to pull it back to the yard but tried it once again before shutting it down and it worked fine.Worked great the next half hour and had to do some heavy pushing and no slipage etc.Any ideas? I'm new to cockshutt and find it hard to get out of gear at times,usually when I push the clutch in the tractor will stop fine but need to wait a few seconds for it to release for easier shifting.I have found though that in low range it does shift easier.Any help on the no go problem?
Jake
Cummins 1955
11-12-2007 03:13:53
 Re: cockshutt 1555 in reply to jakemb, 11-10-2007 13:04:27
Our 1955 done this as well and what happened to be the wrong was the high low shift did not engage. Our gear shift was worn caused this as well as letting it get into two gears at once. More than once we had to pull gearshift and use pry bar reset the notches. We finally welded up the gearshift to prevent it. Until we was told how to fix it we just used nice sharp shifts instead od going at angles and trying to make two shifts at once.
Don-Wi
11-10-2007 14:37:03
Being able to put it in gear w/out the clutch kinda makes me wonder if something is going on in the clutch, but everything else you found is pretty common on all Oliver's, which your Cockshutt is, just painted red instead of green.
Donovan from Wisconsin
jakemb
11-10-2007 15:09:33
 Re: cockshutt 1555 in reply to Don-Wi, 11-10-2007 14:37:03
my first thought was clutch but the input coupler was turning ?? used it for another hour and seems fine now,it's done this in the past put thought i didn't think i had put it all the way in gear but today was the first time i tried putting it in and out of gear with out putting the clutch in. hopefully it makes it threw the winter as this was to be my snow removal machine. half mile driveway to clear at our new property. thanks for the help
jake
