880 power booster dont work
Ed Hodge
11-10-2007 13:02:10
my 880 oliver power booster dont work and the 3 point dont work as well does ant one know why???
help
Ed Hodge
11-11-2007 05:54:01
 Re: 880 power booster dont work in reply to Ed Hodge, 11-10-2007 13:02:10
the power booster is in low side wont go into the high side it slips some times. it all so has a steel fluid line going into is this driven of by the hyd pump?? for the 3 point its power traction hitch it goes up but dont go down the hyd sys. has two filter one on the side of the hyd controle box and one on the console with to small lines going to it i dont know what thay go to
J Schwiebert
11-10-2007 17:39:47
Come on here: What does not work on the Power Booster, High range, low range, it slips, makes a noise, what is the problem? On the 3 point is it a power traction hitch or a hydra hitch, Does it go up manually and not electrically ? Does it leak? settle, make noises, does the trailing cylinder hooked to the other outlet work? Your version is like some of these high school kids I have to work with, There goal is to keep it short and sweet and not tell you much because then you can not tell them they did not get all the facts .
