White Plow Parts...
MH
11-09-2007 07:16:59
Anyone know of a web site that lists plow parts & prices for White plows? Looking at a 4 bottom 3pt hitch plow locally. It needs new moldboards shins & shares, just want to see what I would be up against before I make a decision.
Thanks,
Matthew
oliver fan
11-09-2007 13:27:39
 Re: White Plow Parts... in reply to MH, 11-09-2007 07:16:59
The Oliver/White plant that made all those parts was closed in 1989. However there is at least three companies that are making replacement/after market parts for plows. After you get the numbers off the moldboards, try a AGCO dealer. They can get the parts you need.
Farmer Jack
11-10-2007 17:21:30
 Re: White Plow Parts... in reply to oliver fan, 11-09-2007 13:27:39
which plant was it that was closed?
J Schwiebert
11-10-2007 17:28:19
 Re: White Plow Parts... in reply to Farmer Jack, 11-10-2007 17:21:30
South Bend home of he Oliver plows.
AB
11-09-2007 13:19:57
Here"s where to get em.
Budn
11-09-2007 07:44:43
I have seen them in the Shoup catalog but when I went to their website all I found was mini moldboards. WWW.shoupparts.com or 1-800-627-6137
Most farm supply stores carry white plow parts. They are very common.
Bud
MH
11-09-2007 08:14:53
 Re: White Plow Parts... in reply to Budn, 11-09-2007 07:44:43
Yes, Tried Shoups earlier & only found the mini moldboards. Probably try & get some #s off of it this weekend.
J Schwiebert
11-09-2007 07:43:33
Shoups? It may make a difference in fact it will but you will need to know the number for the moldboard which is stamped in the back.
