OLIVER 990 or Super '99' OLIVER
JERSEYDEVIL
11-05-2007 20:27:31
Would any know where I might find a clutch and pressure plate--foot clutch type,for an OlIVER, 371 Detroit powered Super'99' or 990 ? Also looking for bellhousings for the same. Your help would be greatly appreated.
JERSEYDEVIL
11-06-2007 19:15:13
 Re: OLIVER 990 or Super '99' OLIVER in reply to JERSEYDEVIL, 11-05-2007 20:27:31
Ollie is fresh out. I have a need for both housings. I do belive you could switch the housing or rather it would fit either 990 or Super 99.So I would be happy to come up with an extra oliver-GM Detroit-housing,I'm building a spare engine.
3-71 Fan
11-07-2007 18:13:35
 Re: OLIVER 990 or Super '99' OLIVER in reply to JERSEYDEVIL, 11-06-2007 19:15:13
True enough. Both the Super 99 and 990 bell housing are unique to the tractor application. The bell housing on the Super 99 is only slightly different than a standard DD bell housing because it has been recessed to accommodate the generator on the side. The 990 bell housing is much different and fits in to the tractor better. I have a 990 bell housing but I believe shipping would be a killer because I'm on the west coast. I'm guessing you are on the east. I think you could use either bell housing and most people wouldn't notice the diffence but a few would.
J Schwiebert
11-07-2007 00:08:09
Did you measure the bolt pattern? Are those bell housings a standard SAE numbered bellhousing?
JERSEYDEVIL
11-07-2007 16:35:08
 Re: OLIVER 990 or Super '99' OLIVER in reply to J Schwiebert, 11-07-2007 00:08:09
NO, They are "OLIVER" exclusive. Everyone that has ever researched the bellhousing, always comes back with the same answer....Find a parts tractor.
QN
11-06-2007 04:33:58
Call ollie 618-664-3050
3-71 Fan
11-05-2007 21:03:44
The bellhousing for a Super 99 and 990 are completely different. You may want to be specific so you get the right one. Which one do you want?
