cam in 66
dblair
11-03-2007 14:27:44
is the cam in a row crop 66 interchangeable with a super 66 ? the super has a better lift
Dblair
11-06-2007 15:37:51
 Re: cam in 66 in reply to dblair, 11-03-2007 14:27:44
thanks again
Dblair
11-04-2007 04:35:51
thanks guys
Dblair
11-05-2007 13:56:40
 Re: cam in 66 in reply to Dblair, 11-04-2007 04:35:51
I do have aluminum pistons 3 3/4 dia and the valves won't feed the gas needed for 3 3/4 pistons . I'm going to the s66 valves and was wondering about the cam
RAB
11-04-2007 03:38:20
I know nowt about the 66, but presumably the extra lift was combined with revised valve timing for extra power, and probably at higher revs. Just wondering whether your pistons are cast iron or aluminium. If aluminium, OK. Possibly not such a good idea if cast iron if you use the extra revs. Also was the inlet manifold and carb changed/improved at the same time? Presumaby no problems with valve springs getting near to coil binding?
Regards, RAB
dan m
11-04-2007 17:53:04
 Re: cam in 66 in reply to RAB, 11-04-2007 03:38:20
the springs will handle the lift. there is only one intake for the 66. the super head had bigger valves.the carbs were the same. the cast pistons will take the rpms. haven't found much difference in the hp.
RAB
11-04-2007 23:12:16
 Re: cam in 66 in reply to dan m, 11-04-2007 17:53:04
As we do not know why, other than extra lift, presumably for extra power, your most recent comments now make it an unworthwhile modification, if no other factors are to be considered? Presumably Oliver (Waukesha?) would have got the cam profile optimised for the 66 head and ports etc, so fuel consumption may be adversely affected by the cam change in a 66? May be like the HP. Not much difference. But I dare say they tested the engines on a dyno to sort it out accurately.
I would not be too sure about the CI pistons. They may handle it but may be at their limits and the bottom end bearings may have a tougher time as well. Again, not a lot of difference but in marginal circumstances could mean the difference between a long-lived and short-lived engine.
RAB
dan m
11-05-2007 19:51:56
 Re: cam in 66 in reply to RAB, 11-04-2007 23:12:16
i turn mine close to 2600. don't farm with it up there,just pull. the only thing that seemed to give up were the stock wrist pin bushings. went to a one piece and they have held up 3 years. checked them last winter and clearence was still good. again i checked both cams in the same engine, over a season each. about 10 times on the dyno. and found very little difference. if i were working with another 66 i wouldn't worry about wich cam to use. from stock rpm to 20% over they both do fine.
dan m
11-03-2007 18:34:47
yes,
