Cummins in 2-155
White Fan
11-02-2007 14:44:05
I've seen a few White 2-155's with Cummins 6BT's installed in them. I have one with a bad engine and am wondering if this an easy conversion to do? Does the flywheel from the Herc. fit on the Cummins?
Thanks!
Rich S
11-05-2007 04:29:17
 Re: Cummins in 2-155 in reply to White Fan, 11-02-2007 14:44:05
This kit is kinda pricy but available.
$1250 for the piece part kit, plus the preped motor $9500 remanufactured 11500 new.
http://www(dot)regierequipment(dot5)com/specials.htm
leroux
11-03-2007 08:59:40
There was an awesome White 170 workhorse 4x4 in the classifieds a couple of weeks ago. For the money, this would be the best all around way to go. It was really priced nice! Wish I could justify a monster like that!
herc man
11-03-2007 06:01:02
If you do the conversion, would you want to sell the herc?
s s
11-05-2007 17:33:36
 Re: Cummins in 2-155 in reply to herc man, 11-03-2007 06:01:02
I have 2 motors out 135/155 white tractors
mkuhns
11-03-2007 05:26:42
What is wrong with the herc? I put a 5.9 in our 2-105 this past winter. One awesome tractor now a 190Hp. You will need a flywheel from a 120 white and I think an SAE 4 bellhousing to bolt the over/under to. I is pretty pricey for these two items $1500. You old clutch will actually fit on the new flywheel, but you should replace it since it is apart. We made our own engine mounts. That was the hardest, most time consuming part of the process. It takes some time to get everything switched around. I would opt for an 8.3 which is the route we will probably go for the 2-155.
