: i started to change the oil in my oliver 60 the : other day. no problem right??
: then i started looking for oil filters. what a : nightmare. : the filter i took off of it was a wix 51105. so i : found a wix 51105. but it isn't the same size. it's longer : and my engine side panels won't shut with it on there. the : filter extends beyond the engine enclosure. : i found a shorter filter -- hastings 405, but i'm : afraid that it's too short. the olver 60 has a : needle which forces the oil into and through the filter : this filter is 4.25 inches long. the needle extends : 4.125 inches. not much additional room. : have i got the right filter?? any suggestions?? My Baldwin filters book shows 2 filters for an Oliver 60
These are Baldwin filter numbers Lube PT302 Lube T303-M The Baldwin book also shows that that a Wix 51105 crosses over to the Baldwin PT302 The only thing I don't know is the dimensions of the PT302 they are not listed. Hope this info helps you out. Good Luck! Post back here with the number of whatever you find that works and is the correct length so we will all know.
