770 Gasoline and Diesel engines
Blue Horse
10-30-2007 05:14:03
Since I am now an owner of a 1964 770 gas row-crop, I was curious as to the engine. Did Oliver build this engine at its' factory in Charles City, Iowa? Or is this engine a Waukesha, which I believe was built in Wisconsin? Was the diesel version built by Oliver? At any rate, I find it a very smooth-running tractor.
J Schwiebert
10-30-2007 17:39:25
 Re: 770 Gasoline and Diesel engines in reply to Blue Horse, 10-30-2007 05:14:03
Rick's reply in simple terms is correct. Now also be advised that Waukesha sold a diesel engine in simple terms that used some of the same parts but had a different combustion chamber and fuel system
rrlund
10-30-2007 06:16:53
They were Waukesha. Gas and diesel. I guess they were Oliver designed,cast in Charles City and sent to Waukesha to be machined and finished.
wpur
10-30-2007 19:26:14
 Re: 770 Gasoline and Diesel engines in reply to rrlund, 10-30-2007 06:16:53
was there any other firing order used for the the gas engine as I have a 1964 770 as well that doesn"t like to fire on the 153624 sequence.
J. Schwiebert
11-01-2007 03:10:48
 Re: 770 Gasoline and Diesel engines in reply to wpur, 10-30-2007 19:26:14
No 153624 is almost a standard firing order for a 6 cylinder inline engine.
